kmanstudios 1,120
I am not sure what you are designing, a pic would be most helpful. But, this is how I cracked the spiralize/vase mode print. It may sound silly, but it showed me the basics of how it could work.
1. Make a cylinder. Just a plain ol' capped cylinder.
2. Bring that into Cura.
3. Tell the top and/or bottom to have no layers or thickness. This will let the top and/or bottom be ignored. If the top only is ignored, you will have a base in the object like a glass. If the top and bottom are ignored (again, ignored = 0 layer thickness or 0 layers) you will get a tube.
4. Turn on Sprialize mode.
5. Slice: This will allow for Cura to see the thickness of the walls and apply the single wall with no issues.
This is a project file with the basic settings I laid out above. The top is 0 layers and the bottom is left at default. The wall count is left at default as Spiralize will overrie that with just one wall. Retraction at layer change is unchecked (turned off) to prevent z-scar from marring the surface.
UM3E_A_Cylinder_in_VaseMode.curaproject.3mf
As @smartavionics mentioned, as long as your slopes are not too shallow, you can use angles and such without worry.
Happy vasing!!
2
Top Posters In This Topic
30
30
25
8
Popular Days
Mar 10
21
Mar 9
14
Mar 7
11
Mar 11
10
Modified_Gemini 30 posts
kmanstudios 30 posts
burtoogle 25 posts
ghostkeeper 8 posts
Popular Days
Mar 10 2018
Mar 9 2018
Mar 7 2018
Mar 11 2018
Popular Posts
ghostkeeper
We get a lot of questions about this actually. We use about 7/8ths of the nozzle size in Ultimaker's printers because adjacent lines tend to adhere better together then. Because the nozzle is a b
kmanstudios
burtoogle
The way Cura works at the moment, when not using spiralize mode, all walls have to have an even number of lines. It modifies the flow of the second line to try and compensate for the overlap but the i
Posted Images
ghostkeeper 105
This is known. It's a limitation of how Cura calculates these things: Your model outline is inset by half the line width. If anything remains, it is printed with the normal line width. If nothing remains, only the "Print Thin Walls" option may still save you. If two lines overlap a lot, then one of the two will have its extrusion rate reduced to prevent overextrusion. You'll ooze some filament there but hopefully not too much since there is a backpressure from the earlier printed line.
In the future I hope we'll implement some sort of minimum extrusion after overlap compensation, such that lines that are reduced to less than 30% of their normal extrusion rate or so will just be left out. That would fix stuff like this.
burtoogle 515
Have you tried the spiralize mode that Cura provides? It works pretty well as long as the slope of the sides is not too shallow.
