I was looking into a way to occasionally print Ninjaflex or other real flexible materials (85A)
There's no way you'll be doing that reliable with a bowden setup (ok, I've seen people using oil in the bowden but nahhh), so I compared a quick and dirty direct drive conversion on an Ultimaker2 head (tested on my DIY GO) and on the ultimaker S5
**** first a warning, Ultimaker does NOT want you to open the S5, it contains an open style high voltage power supply, so it'
