Hi there
I tried to slice my file with the temperature of 400°C but cura tells my that my temp is to high. I own a Funmat HT which can handle this temperatures.
I have searched all over cure to setup the max temp for the nozzle but could not find it. How can i setup the right settings?
The limit is 365. It is set in fdmprinter.def.json, but I discourage you edit that file because (1) it affects all printers, and (2) you have to make those edits again if you ever reinstall Cura or install a new version. The better option is to override the maximum in the printer definition you are actually using (provided you are not using a "Custom FFF Printer").
