When I load a 3mf into Cura 5.2.2 the model drops on the left front edge. I know I can move it to wherever I want using the cursor but I was wondering if there is a setting to have it drop in the center.
Cura behaves different with placing a model as a .STL or .3mf file. While a .STL file will be placed in the middle of the print plate, it will place a .3mf file related on the model coordinates and its center of origin in xy. This is what you are recognize when you import your model as 3mf. Here a example how Cura behaves with a simple model exported from Fusion360:
Model (out of center of origin at x=-15mm,y=20mm):
Imported as STL:
3mf impo
