DivingDuck 94
Cura behaves different with placing a model as a .STL or .3mf file. While a .STL file will be placed in the middle of the print plate, it will place a .3mf file related on the model coordinates and its center of origin in xy. This is what you are recognize when you import your model as 3mf. Here a example how Cura behaves with a simple model exported from Fusion360:
Model (out of center of origin at x=-15mm,y=20mm):
Imported as STL:
3mf import:
The mentioned machine setting for center of origin defines the center of origin how the printer interpret the coordinate system. This is for a rectangular bed usually at the front/left side at xy 0,0 (as you can see in my pictures above). For a round bed it is in the center of the bed at xy 0,0. For my bed center of origin is xy 0,0 while center in the middle looks like below.
This do not change the behavior for importing a model and where the model is placed.
Edited by DivingDuck-
2
Dustin 55
Uncheck origin at center.. I very much doubt your firmware is configured that way..
RonS 0
Hi Dustin
I've turned that on and off to see if it helps, it didn't make a difference either way. I guess I took a snapshot of the screen while it was still on.
Is there something else I might turn on or off?
Thanks
