callum-burns
31 -
Never
Posts posted by callum-burns
Yeah, I'll admit I read the thread a bit hastily. I just assumed that he wanted to use the higher voltage for the board as well as using the same voltage isn't much of a change
I was also unclear about the 7812 not being able to handle 24V, I should've clarified that I meant without additional heatsinking.
I need to stop bouncing between tabs and reading different things while replying to topics
Haha guilty of that too sometimes.
I am planning to do the exact same thing with my machine so also curious if nobody has input to why it wouldn't work...
Seems like people are generally misinterpreting your intentions though...
The way I understand you (and the same way I was planning to do it) is like this:
- Buy a 24V PSU large enough to handle both printer and HB (I think 150W might be too small, I got a 350W myself)
- Connect the HB directly to this PSU through a relay controlled by the HB outputs on the UM board
- Connect the UM board to the PSU through a DC to DC converter that regulates down to 19V
So HB gets 24, UM board 19 and you don't need to change anything on the board itself
Exactly the way I was thinking but without the relay. I was going to unsolder the Mosfet, take a wire from the gate pin to the mosfet thats on a external board that then allows you to use the 24V with the loveliness of PWM! Also gets rid of that ticking from a relay!
I wouldn't need extra cooling as there will still only be 19v going to the board. The dropper would be an external device bolted to the bottom. If you can see where I am coming from. From my readings the UM uses 70-80w at 19v so a 150w dc to dc would do fine.
I would be feeding 19v into the ultimaker board via the dc to dc dropper. Meaning I don't need to change anything on the board.
I have a brain fart of an idea on how go use a 24v psu with a ultimaker. I though that using the full 24v for a heated bed then using a dc to dc converter to get to the 19v for the rest of the electronics. Anyone see any issues with this idea? I have found a few 150w dc to dc converters on eBay so seems it will have enough juice.
Just downloaded Cura 14.01 for the first time on my Mac running Mavericks. I keep getting an error saying Cura: Cura Error. With two options: View Console or Terminate. The Console has nothing apart from Cura: Cura Error in it. Downloaded 13.12 and thats the same too. What could be the issue?
Bring me your bugs! Cura 14.02-RC2 ready for testing.
in UltiMaker Cura
I am still getting that non discript error "Cura Error" while trying to start the program. OSX 10.9.1 Mavericks.
