When layer height is 0.4mm,cannot generate raft?
Cyndent
Posted · When layer height is 0.4mm,cannot generate raft?
I try to use a nozzle of 0.8mm and layer height is 0.4mm. Cura cannot generate raft. When I change layer height to 0.3mm, raft generated. The engine can generate raft when layer height below 0.3mm. Is that right?
