Command to Send gcode to printer directly
debakanta
Posted · Command to Send gcode to printer directly
Is there any option in cura to give print command from command prompt so that the gcode file will be printed following loading , connect to proper port of the printer and suitable baud rate..
Thanks & Regards,
Debakanta
        • 4 replies
