Y extruder JSONs for CURA 2.4 Working
Dagnall
Posted (edited) · Y extruder JSONs for CURA 2.4 Working
I have now got a set of Extruder and Machine Jsons that load and work
the extruders have "start and end" Gcode definitions that are essential for the Y extruder as it requires a lot of filament to be pulled back before swapping to the next filament.
There is room for improvement in the pull back code as it could do with a little push pull sequence to make the pulled back end neat.
For anyone else wanting to experiment with the Flux Capacitor dual extruder, the Json can be found at
https://github.com/dagnall53/JSONS-for-Cura2_3
        • 4 replies
