Project Planner Question
johna
Posted · Project Planner Question
Easy question for a new Cura user:
When you use the project planner, what 'print type' (or profile) does it use? It doesn't seem to have the same choices as the Cura main window.
    It uses the profile from the normal mode in the main window. Yes, this isn't clear at all, and bound to change in the May release.
