Gcodes for starting script for UM3 using S3D
The3DPrintStudio
Posted · Gcodes for starting script for UM3 using S3D
The default starting script for simplify 3D is:
M106 S0 ; fan off
M204 S1500 ; default acceleration
M205 X15.00 ; maximum X Y jerk
T0
G1 X2 Y5 Z5 F15000.0 ; heating location
M140 S[bed0_temperature]
M104 S[extruder0_temperature] T0 ; heat left
M190 S[bed0_temperature]
M109 S[extruder0_temperature] T0 ; stabilize left
G1 Z0.2
G92 E0 ; zero extruder
G1 E30
G1 X100 E15 F1000 ; purge left extruder
I would like to modify this to still go to X2 Y5, but instead of purging the extruder from x2 to x100, do a Cura style purge where it just depositing a large blob of filament. I found this does a better job getting rid of any different color PLA when swapping colors. What would be the best way to change this to do that. I know G280 does the filament purge on the UM3, but I'm not sure what to remove/replace.
