Hi, Thanks for the reply.
But I do not quit understand what you mean, I do not understand what (arduino?) to screw loose form the main board, is that the small board on top of the big one? Than after connecting to the computer and do the firmware update (with cura I guess) I have to replace.... I understand; place it back?
I think the whole operation is quit scary, and I do not understand Ultimaker to let their users go through that hell since almost everybody uses Win7....
Groet Dree
phanc60844 0
Although my issue wasn't quite the same ,just try removing the arduino from the main board ,then try to establish comms and download the current firmware. Replace the arduino on the main board (carefully as others have fried components when the arduino wasnt connected to the correct pins) and then see if you can see the device.
Paul
