Nozzle stl file
Posted · Nozzle stl file
4 minutes ago, DidierKlein said:
Hi and welcome,
What nozzle?
I didn't check but it might be in step files on the Ultimaker github?
i would like to print ultimaker nozzle with ceramic material by DLP printer to test some filled filaments, any nozzle diameter,
Thanks
    Look here:
    https://github.com/Ultimaker/Ultimaker2Plus
    PART 2313 should be the standard 0.4mm nozzle (can't check the file right now).
    thank you but it does not look like complete model, there is no threds on it to fix
    thread should be M6 if im not wrong?
    Thank you very much
