Can not assign 2nd Dual Extruder to part
IvoPi
Posted · Can not assign 2nd Dual Extruder to part
Hello all,
Suddenly started having a problem today setting up dual extrude models in. Cura 4.4.  I had not had a problem til not and not sure what is going on.  Previously I could assign each extruder to the solid and then merge and slice but not one extruder always shows a striped pattern (see pic) and Cura will not slice it.
Any clues.
Thanks in advance
Ivo
