Chemical resistant filament to amines
Posted · Chemical resistant filament to amines
Hello,
Does anyone have experience with chemical resistant materials, specifically against amines? I want to print an epoxy extruder and the amines in the hardener are quite destructive to most plastics.
I've been systematically reaching out to many of the third party suppliers on the Ultimaker Marketplace but wanted to query the community to see if anyone has some specific recommendations.
Thank you!
    Hi Justin,
    If you look in this paper
     https://www.sciencedirect.com/science/article/abs/pii/S2214860418303476 (unfortunately not open access but there is an amine - ammonia which they tested on different filaments).
    If I look at what chemicals are resistant to 25% ammonia: PET(G) / NGEN / CPE, PP and ABS/ASA seem to work reasonably. Materials to avoid are PLA, PC and Nylons.
    I guess your safest bet might be PP or a PVDF filament like the one from Solvay. Alternatively, if your printed part is very complex / prone to warping a copolyester like PET(G).
    By the way, you can also look into general material properties (outside of FDM) for amine resistance, in principle that shouldn't change with the processing technique (the chemical resistance comes from the material anyway).
    • Thanks 1
    Thanks @TimonR! Many of the individual suppliers have been suggesting PP as well. I think I'll just need to try a few.
    Thank you for recommendation to look into general material properties outside of the FDM world. Great idea!
    • Thanks 1
