Scaling dimensions printing to small Help
Johnmgg
Posted · Scaling dimensions printing to small Help
Hi all,
Scaling dimensions. I need some help. I made a design in Shapr3D on the iPad. I imported design into CURA 5.2.1. The file is in the .3MF file format. Other than adjusting the Z Scaling dimension from 50-70mm X and Y are correct. Around 134mms. But when I print the design the design is 50ishmm in diameter. It should be about 134mm in X and Y. Is anyone else having issues. I have to up scale my design to 150% to get about the right dimensions. It looks on the simulated build plate to be about the right size, as far as I can tell.
Thank You for any help.
