Calibration wrong in only one corner
elso
Posted (edited) · Calibration wrong in only one corner
Hi guys,
I hope you can support me with the following issue. My Ultimaker 2 is perfectly calibrated on three points on the bed, but the fourth point right corner in the back is ~2mm too high. I already measured the distance of the steel rods to the top of the chassis, but can't observe anything being off there. Do you have any idea what I can touch to solve this?
Thank you 🙂
Edited by elso
