UMS3 - small gaps / zits and blobs
Xhoax
Posted (edited) · UMS3 - small gaps / zits and blobs
The viber statues we print have zits/blobs on the surface.
It seems like its the transition from the support to the wall surface.
On the last photo you also see the stringing from the support to the outer wall.
Is this an overextrusion problem?
How we can improve this?
Printer: UM S3
software CURA 5.6.0
material: VIBERS  Colorfabb
nozzle: 0.6AA
layer height: 0.12
print temp: 200
bed temp: 20
flow: 103
Print speeds + infill: 50
print speeds all wall speeds: 30
Edited by Xhoax
        • 4 replies
