Try removing the flto flag from the compiler and linker to see if that helps. It might be an obscure compiler bug (normally the assembler should never throw an error)
Using gcc-4.7 (which can be installed on Raspbian with "apt-get install gcc-4.7") and removing all references of -flto from the Makefile seems to work with the latest git version of CuraEngine.
Here's a patch to apply to the CuraEngine Makefile:
--- Makefile.back 2014-07-03 01:13:28.431840101 +0000
+++ Makefile 2014-07-03 01:13:20.222592688 +0000
@@ -12,6 +12,8 @@
CXX ?= g++
CFLAGS += -c -Wall -Wextra -Wold-style-cast -Woverloaded-virtual -std=c++11 -DVERSION=\"$(VERSION)\" -isystem libs
+FLTO = #allow for enable/disabling of link-time-optimization. Pass FLTO=-flto to enable. Default is disabled.
ifeq ($(BUILD_TYPE),DEBUG)
CFLAGS+=-ggdb -Og -g
endif
@@ -38,16 +40,16 @@
ifeq ($(OS),Windows_NT)
#For windows make it large address aware, which allows the process to use more then 2GB of memory.
EXECUTABLE := $(EXECUTABLE).exe
- CFLAGS += -march=pentium4 -flto
- LDFLAGS += -Wl,--large-address-aware -lm -lwsock32 -flto
+ CFLAGS += -march=pentium4 $(FLTO)
+ LDFLAGS += -Wl,--large-address-aware -lm -lwsock32 $(FLTO)
MKDIR_PREFIX = mkdir -p
else
UNAME := $(shell uname)
ifeq ($(UNAME), Linux)
OPEN_HTML=firefox
- CFLAGS += -flto
- LDFLAGS += --static -flto
+ CFLAGS += $(FLTO)
+ LDFLAGS += --static $(FLTO)
endif
ifeq ($(UNAME), Darwin)
OPEN_HTML=open
This way you can call "make" and get a non-lto version (buildable using gcc-4.7), or call "make FLTO=-flto" to get a version with link-time optimization (buildable with gcc-4.8). If gcc-4.7 is not the default (Can be checked by calling "gcc --version"), then you'll have to run "make CXX=gcc-4.7".
aurock 2
I was able to successfully compile from commit d7d9b5b9a4a5aa6b138a3fa1e3c19b2f5f50f5bd.
