Software Profiles
ianadan
Posted · Software Profiles
Guys
Is there a way to get the default Printrbot profiles to have the correct nozzle diameter from install.
They install with a diameter of 0.5mm when the Printrbot's have shipped with 0.4mm nozzles for ages.
Love the software otherwise
Ian
    Hi Daid
    The nozzle diameter was the main thing. The Metal Plus also has a Duel Extruder version, which has slightly restricted print limits, Do you include these in 'New Machine' profiles?
    Ian
