roald
43 -
Posts posted by roald
since a few days my ultimaker original starts with a temperature drop at layer 3 and it drops from 220 degrees to 200 degrees Celsius and ruin a few layers. after layer 11 the temperature stabilize and the other layers going well.
things i have already try to solve the problem:
restart windows pc
re-install cura
try another usb port
drive from a mac pc (with a older version of cura)
disconnect the printer for 2 hours
check the cables on the board and print head
expand the distance about the power cables from the heated bed and the signal cable from the temperature sensor
i have compare some datasheets and i think this is the best relay for me:
panasonic ew - ale1pb18 - relay ,pcb, spno 16A 18vdc
http://pewa.panasonic.com/assets/pcsd/catalog/ale-catalog.pdf
i have made this decision about;
*coil voltage 18vdc close to the 19v output on the board
*coil current 22,2mA low coil current the board have enough power to drive the relay
*spst-no contact i dont need no more contacts
*good price
i hope i choice the right one and it will work this time
oke what do you think about this one ''omron g2r-1a-e 18vdc''
its from the same series and the voltage lay a lot closer to the 19v that i measure on the board.
hey AaronAlai, gr5 thank you for answer my questions. i learn every day more and more about the electronics of my ultimaker
today i connect the relay to the 12V battery of my car and it works. after the good results with the car battery i want try it again to my ultimaker port but the tiny contact of the coil broke before.
i also call my colleague today the one who gave me the relay, and he tell me that it should be possible that i can connect the coil in only one way (i'm always thinking i t makes no different)
he also tell me that it is possible to connect 19v on the coil but it reduce the life cycle of the coil.
tomorrow i order a new relay and also a component to reduce the voltage from 19v to 12v to spare my coil.
i let you know if it works.
and yes gr5 i have a multimeter
- [*]RELAY, PCB, SPDT, 12VDC, 10A
[*] Product Range: OMRON - G2R Series
[*] Coil Voltage: 12VDC
[*] Contact Current: 10A
[*] Contact Voltage VAC: 250V
[*] Contact Voltage VDC: 30V
[*] Contact Configuration: SPDT
[*] Coil Resistance: 275ohm
[*] Relay Mounting: Through Hole
[*] SVHC: No SVHC (20-Jun-2013)
[*] Coil Current: 43.6mA
[*] Coil Type: DC
[*] Coil Voltage VDC Nom: 12V
[*] Contact Current Max: 10A
[*] Contact Voltage AC Nom: 250V
[*] Contact Voltage DC Nom: 30V
[*] External Depth: 13mm
[*] External Height: 25.5mm
[*] External Width: 29mm
[*] Mounting Type: PCB
[*] No. of Poles: 1
[*] Nom Operating Power: 530mW
[*] Operating Temperature Max: 70°C''
[*] Operating Temperature Min: -40°C
[*] Relay Type: Power
this are the specifications of my used relay. today i disconnect the two wire's brown and blue from the motherboard and connect those wires from the coil to a 12V battery loader and again no switch!!
do i something wrong? or is it broken? and when it is broken can someone advise me witch relay i must chosen?
i always order at webshop Farnell
i appreciated all your good helps guys
1 i have remove the second diode
2 i disconnect the brown and blue wire and measure 19V on the contact and the led light up
but still no relay switch!!
oke i have build the marlin firmware and change the options ''template'' , ''choose options'' , and ''heated bed temperature sensor''
the rest i don't change. and load the HEX file in cura.
now cura display the the bed temperature but the relay don't switch and the bed stay cold
hello,
i have made a self build heated bed for my ultimaker original, and connect all the electrical components like the scheme
i have also selected the option heated printer bed (self build) in the configuration wizard and set it to 70 Celsius degrees
but when i hit the button start print in cura the relay don't switch and the bed stay cold?
illuminarti your right, when i push the feeder with my finger, the wheel come inside the body (see picture) and i tightening the screw from 14 first to 11,5 now. it looks like it helps a bit the gapes on the top are less
the second thing that i will make better is my belt tension.
when i watch the movie about belt tension i realize mine is to soft but the problem is there is no space any more to tighten it with the screw its on the end en the screw eats a little in the wood (see picture)
i was forgot to tell that the print on the picture is printed without cooling it is because my transistor is blown and a new one is in order. (i think that's why it pillows on the top)
i check the distance of the spring and it is 14mm and i can fasten the screw no more than that because the axis from the wheel hit the end.
also i had reassembled the part on the foto and check of everything is oke.
first thank you all for the help. today i have make a new print with other settings and i had make some pictures and videos of the results from the test print.
first layer
second layer
as you can see i can only make a solid bottom when i print really close to the platform and extrude enough filament to splash the lines to fill the space between the lines.
hello everyone,
every time when i try to print something, the printer lay the lines not close enough together.
what results in some little gapes/raster in the top and bottom layer.
how can i fix this ?
i found different types on the same number BD679 by Farnell which one i must choose ?
yes i have the blue and purple wire attached under the printer with the 12v battery the cable is oke.
i try to order the BD679 darlington transistor replace it, i let you know if it have solve the problem thanks for your fast help
Maybe when you put 12V on the wires you fixed something? Loose wire?
you mean there is maybe a cable break or a not good connected wire?
hello, the fan printhead from my original ultimaker wont work anymore?
when i connect my printer with the powercord and usbcable en put the power on
i have a voltage of 19V on the purple and blue wire on top of the printhead. and when i start printing the voltage drops to 14V but the fan wont start to drive anymore??
when i test the fan on a 12v battery it works.
anyone a idea what is wrong?
Roald
howto control my self build heated bed with Cura
in UltiMaker Cura
yesterday i have receive my ''panasonic ew - ale1pb18 - relay ,pcb, spno 16A 18vdc'' relay and implement it
and it switch and everything working well.
problem solved thanks for all the help
