engr
32 -
Posts posted by engr
You are omitting the port number (see the :8080 part):
http://[ip address]:8080/?action=stream
Thanks. That works.
This method doesn't seem to work (anymore?). UM3, firmware 3.6.2.20170322. Unless I'm doing it wrong....
http://[ip address]/?action=stream
just redirects to
http://[ip address]/start.html
and prompts for the Welcome to Ultimaker 3.
Camera streams OK to Cura though.
Has anybody tried ETHY-LAY or similar support material (alcohol soluble)? Thoughts or advice?
Any suggestions about do/don'ts or good/bad primary material combos?
How about with Polycarbonate?
https://www.matterhackers.com/store/3d-printer-filament/lay-away-ethy-lay-support-filament-3.00mm
@kmanstudios Maybe this question can be moved to another forum category for more response?
Somebody above said
If I wanted to use Polycarbonate, what can I use for supports?I have the same question.
What are the new compatibilities concerning PVA as a support and other materials other than PLA and Nylon?
I'd like to hear answers/comments on this too.
My first print with PC/PVA on UM3 didn't go well. PVA doesn't seem to adhere to PC.
Status of print job without using Cura
in UltiMaker Cura
What's the best way to check on the status of the print without using Cura?
I don't like to keep Cura open because it makes my PC spin up loud, but I'd like to know time remaining, temperatures, etc.
I got the webcam streaming in a browser, so that's not a problem.
I can get the times with a bit of work using
but I have to do calculations to change the seconds into hours, % remaining, etc.
And I can find temperatures in a similar way, but again not very user friendly.
Has somebody made a script or applet that does this?
