Changing UMO+ Home sequence
neotko
Posted · Changing UMO+ Home sequence
I want to change the 'home' button on prepare on my UMO+ to have a safe home button for my Dual Extrusion Magnet Head Changer setup (DEMHC :D ! )
I will like to ask to someone with marlin knowledge if the area I need to rewrite on the firmware it's this:
Ultracld.cpp
static void lcd_home(){   enquecommand_P(PSTR("G28"));   enquecommand_P(PSTR("M84 X0 Y0"));}
I assume I can add as much 'enquecommand_P....' to place my home gcode as I want?. Thanks!
