Maintenance Schedule
Posted · Maintenance Schedule
Hi, I'm a new Ultimaker 2 Extended owner.  I use my machine rather consistently and so I wanted to put together a more efficient way to maintain it than "oh look the print is messing up what do I need to adjust/replace? Let's go through every single possibility to figure it out."
So my question to you more experienced users is what kind of schedule should I keep in mind for maintaining different parts of the printer?  These would include:
Atomic Cleaning
PTFE coupler replacement
Reapplying glue (I do this every time to be safe but is it necessary?)
Scrubbing down build plate
Lubricating X and Y axes
Lubricating Z axes
Tightening Belts
And any other part of the machine that might need occasional attention.
I feel like having an hour range after which I know I need to check something would keep everything running a lot smoother.  I'd waste less filament and also spend less time troubleshooting.  So any tips?
