Posted · Negative skirt ?
Just noticed that Cura when slicing big models (190mm x 190mm), generates negative coordinates for the skirt, this results in the Z cooridinate not being set and the first layer printed "in the air"
;LAYER:0
;TYPE:SKIRT
G1 X-1.874 Y4.965 Z0.2 F9000.0
G1 X-1.807 Y196.797 F900.0 E3.5093
G1 X1.318 Y200.753 E3.6015
G1 X4.965 Y201.874 E3.6713
G1 X197.259 Y201.806 E7.189
G1 X201.806 Y197.259 E7.3067
G1 X201.874 Y4.965 E10.8244
G1 X200.753 Y1.318 E10.8942
G1 X196.797 Y-1.807 E10.9864
G1 X4.965 Y-1.874 E14.4957
G1 X1.734 Y-0.881 E14.5575
G1 X-0.881 Y1.734 E14.6252
G1 X-1.874 Y4.965 E14.687
;TYPE:WALL-OUTER
Simpel fix is of cause just to edit the .gcode file and change the negative X value to 0.
Is this on purpose ?
/Erik
    Those moves are outside of the machine, so the print you are trying to make is larger then the machine, which is causing your problems. You can reduce the skirt distance, or disable the skirt.
    • 4 months later...
    I am having the issue that the skirt seems to extrude too much. The print itself prints at the right thickness, but the skirt just oozes out. This wouldn't be a problem if on the second round of the skirt the extruder didn't strip itself trying to print on this thick layer. I noticed that the small herringbone gear that I have was tightened too tight and that the nut is pulling through the plastic, so I ordered a set of spur gears from shapeways. But I don't think that is the main problem, I think it is somewhere in the settings.
