Marlin Builder and default values as used / shipped
Posted
· Marlin Builder and default values as used / shipped
The defaults of the builder are good.
About the PID: The tooltip is older, the new settings work better.
About the max feedrates: It's a bit of a preference, normally you never hit the max feedrate of 45 (45mm per second of filament extrusion?!?). But some people prefer "unlimited" which is the 500k.
The UltiController (as produced from the shop by Ultimaker) and the UltiPanel (beta versions, and version on thingiverse) are slightly different in how the rotation knob is wired. Other then that they are the same. The main difference is that the menus will rotate the wrong way around if you use the wrong panel type.
If you enable the UltiController or UltiPanel, then the "Enable SD support" checkbox no longer matters, it's always compiled with SD support.
The firmware shipped with Cura is build with the Marlin builder, at a point where Marlin was very stable. This firmware was build with the defaults of the builder, except that I also turned the UltiController on.
I also tested that firmware for 3 weeks before I shipped it in Cura. And many people are using this exact firmware now.
The Marlin builder is currently running newer firmware then that, with a few new features like long-filename support. So there is the potential of problems, but so far it has been running stable on my machine.
Daid 303
