Posted · Marlin going faster with low feedrates?
I wanted to print something really small, with as much detail as possible. So I tuned down the temperature as much as possible, and set the feedrate to 10mm/sec.
But if I print now with Marlin it doesn't go slow, it goes faster then GCode with 60mm/sec. Any idea what's causing this? (I'm using a slightly older version of Marlin)
    Ignore this, seems to be related to the version of Marlin I had. I updated to the ErikZalm/Marlin/Marlin_v1 branch. And now the feedrate seems to work better.
