My Print button turned into Save Toolpath
ken-brooks
Posted (edited) · My Print button turned into Save Toolpath
Until a few days ago the middle button at the top of my Cura window said Print and did exactly that.  Suddenly with the program running it changed to saying Save Toolpath.  I fixed this once by rebooting... but no more.  It changed again and won't change back.
My printer is a Printrbot and it doesn't take an SD card.  How can I convince Cura that I really just need to print directly?  Is there a setting somewhere?
Cura 15.02.1 of Feb 19, 2015.
MacOS 10.6.8
    Posted · My Print button turned into Save Toolpath
    And make sure the USB port you are using is working properly.
    Thanks, dim3nsioneer. The USB port was the whole issue. Boy, I wish they made that a little more self-explanatory!
