Cura 15.06.xx : Fix Horrible - Combine everything
Matdu10
Posted (edited) · Cura 15.06.xx : Fix Horrible - Combine everything
Hello guys!
I have encounter one problem with new Cura version. Here's 2 pics that show the problem :
Cura 15.04 : http://i.imgur.com/6tleCLd.png?1
Cura 15.06.03 : http://i.imgur.com/wD1Dihb.png?2
As you can see, Cura seems to create gaps in pieces. So, I don't know if it due to the new version, or if it is some parameter I coundn't find, but I thought that needed to be noticed.
Edit : I just find out that the same thing appeared in Cura 15.04 if I uncheck "Combine everything (Type-A)" under Fix Horrible. I changed the title accordingly.
So, is this option still available in Cura 15.06 and I missed it out? Or is it gone?
        • 10 replies
