Ultimaker Original+Heated Bed Kit + New Cura = help?
Titus
Posted (edited) · Ultimaker Original+Heated Bed Kit + New Cura = help?
Hi all,
I'm busy installing my HBK into my UMO, and looking at the new motor+screw, I can imagine there should be something that changes in the firmware. With the old Cura you could select upgrades after you selected an UMO. Now there's no such option, so how should I fix that? I'm guessing old Cura for firmware update, then run new cura with UMO settings?
Or is the travel of the Z motor the same and doesn't it matter at all that my HBK is installed?
Thanks!
    Posted · Ultimaker Original+Heated Bed Kit + New Cura = help?
    Unless it's to update the firmware, you could just choose umo+ so the gcode works with your umo hbk. But don't connect it to change firmware if you do that, just to make the gcode.
    I think inside the cura files you should find the .hex file for your original with hbk.
