Stringing and combing
z-axis-3d
Posted · Stringing and combing
I am getting stringing due to the head travelling across the part.
If I enable combing ON then the layer view shows the head travelling around the entire profile to the same start point for the next layer. This increases travel time when I would really rather the head alternate the direction for each layer -IOW start the next layer on the same side rather than travelling across.
Is that possible in Cura? Could I use a tool to modify the STL to remedy this?
Any advice would be appreciated!
Thanks,
Greg
5a33119487878_2015-09-2614_34_24-Photo-GooglePhotos.thumb.jpg.040bbe535e42d0bd27e32bc20ad86c83.jpg
    Thanks for the useful hints! I had tried to decrease the temperature as far as I thought reasonable, but Z-Hop was 0 so I'm sure that will help in future.
    However in the meantime I tried a repair in netfab and then reloaded the reparied stl and it is no longer tracking across the part on each Z-increment. This has also saved me nearly an hour in print time on a 10.5 hour print. (I'm sure increasing the travel speed would have helped there too.)
    Thanks again,
    Greg.
