how is netfabb pulling it off ?
could you not take an idea from them ? and solve this problem.
I am also getting this problem but in a very big way. arch houses 1:500 have a lot of thin walls :cry: :cry:
best wishes.
Ian
best wishes.
Ian
Thanks for the tip. Your suggestion worked and I now have solid filled walls.
Daid 303
Try setting the wall thickness to 0.4mm, this should put down 1 side line, and then put infill in between. The problem is well known as the "thin wall problem", Cura refuses to put infill in between thin walls. There are lots of test cases for this, and lots of proposed sollutions, but going from an idea to a real implementation proved to be difficult so far.
