Source code for updating Firmware
Srujana
Posted · Source code for updating Firmware
Hello,
Can i know how to use the source code (as open source) for updating Firmware in Cura .
i.e., How and in which file should i make changes to update fimware in software.
Thank you.
    Posted (edited) · Source code for updating Firmware
    To update firmware, the easiest way is to take the latest version of Cura, which gets you the latest release build of the firmware and allows you to update it via a USB cable.
    If you'd like to compile/verify the firmware yourself or make changes to the firmware, download the source code from here (assuming you use an Ultimaker 2): https://github.com/Ultimaker/Ultimaker2Marlin
    It includes instructions on how to compile it (using Arduino's IDE) at the bottom of the page. You can make any changes you like to the entire source code.
