Posted · Cura 15.06.03 - Not Slicing or Calculating or Saving
Yesterday Cura was working fine, however today it is not working...
- Models Loads correctly and shows in solid view.
- However, Cure then does not calculate
- Layer view is blank (sometimes shows blank layers 0-11)
- Save button is grayed out
I have tried reinstalling, restating and various models including models I have previously printed successfully.
Engine log is blank in Help > show engine log...
Similar Posts have indicated that it is an antivirus issue on CuraEngine , but this appears to have installed correctly and Cura was working correctly until today so I do not think it is an install issue?
In User>App Data> Local > Cura > Curalog
2016-01-18 12:44:43,083 - INFO - Loaded plugin FileLogger
2016-01-18 12:44:43,224 - INFO - Loaded plugin LocalFileStorage
2016-01-18 12:44:43,231 - INFO - Loaded plugin LayerView
2016-01-18 12:44:43,242 - INFO - Loaded plugin MeshView
2016-01-18 12:44:43,253 - INFO - Loaded plugin WireframeView
2016-01-18 12:44:43,258 - INFO - Loaded plugin OBJReader
2016-01-18 12:44:43,260 - INFO - Loaded plugin STLReader
2016-01-18 12:44:43,265 - INFO - Loaded plugin STLWriter
2016-01-18 12:44:43,269 - INFO - Loaded plugin GCodeWriter
2016-01-18 12:44:43,277 - INFO - Loaded plugin CameraTool
2016-01-18 12:44:43,284 - INFO - Loaded plugin MirrorTool
2016-01-18 12:44:43,297 - INFO - Loaded plugin RotateTool
2016-01-18 12:44:43,305 - INFO - Loaded plugin ScaleTool
2016-01-18 12:44:43,313 - INFO - Loaded plugin SelectionTool
2016-01-18 12:44:43,321 - INFO - Loaded plugin TranslateTool
2016-01-18 12:44:43,333 - INFO - Checking for new version of cura
2016-01-18 12:44:43,333 - INFO - Loaded plugin UpdateChecker
2016-01-18 12:44:43,353 - INFO - Loaded plugin USBPrinting
2016-01-18 12:44:43,363 - INFO - Loaded plugin CuraEngineBackend
2016-01-18 12:44:44,099 - DEBUG - Loaded theme C:/Program Files (x86)/Cura_15.06.03/resources/themes/cura
2016-01-18 12:44:49,494 - DEBUG - Loaded a mesh with 199773 vertices
Any idea whats going wrong, advice would be greatly appreciated, thanks in advance!
    To add to the mystery, I uninstalled the version 15.06.03 and downloaded and installed various versons of 15.10. From:
    http://software.ultimaker.com/Cura_closed_beta/15.10/
    Win 64 Nov 1st version - The model is perpetually slicing (even really tiny models)
    Win 64 Nov 17th version - The issue is the same as described in the original post
    Could there be some user setting that is being brought to the different versions?
    Further experimenting on a different computer using the same stl files and 15.06.03 versions of Cura have worked. Which makes me think the issue is something local?
    Posted (edited) · Cura 15.06.03 - Not Slicing or Calculating or Saving
    So I kept fiddling around and have found a solution that appears to have worked:
    With the win 64 Nov 17th Cura Version installed
    -Close Cura
    - Delete all files in:  C:\Users\user\AppData\Local\cura
    - Restart Computer
    -Re-Open Cura
    Then hopefully it should work!
