Posted · Moving Ultimaker and slippage FIXED/SOLVED
I recently moved the Ultimaker into another room for some long printjobs (for noise reduction).
After moving it back to the usual place, i tried to print some normal sized objects from SD Card - and they failed after the first layer with heavy slippage in X _and_ Y direction :shock:
Tried again, same slippage at the exact same location. Tried CURA instead of SD Card (and sliced it anew) - slippage.
Tried another object in CURA, sliced with lower speed (75 instead of 100mm/sec) - slippage.
Checked the belts (long and short) - all ok, making a bit of a "twang" sound.
Checked the rods - all clean, moving without problems, had a drop of oil a few days ago - nice and shiny.
But then I found the solution - the moving seems to have loosened the screws on the motor-mounts a little tiny bit - just enough that at the moment, both motors kicked from "first layer speed" to "print high speed" the motors did give in a little and slipped.
Re-tightened the motor mounts (which i didn't have done, as the short belts felt tight enough).
I also noticed, that I could re-tighten all the enclosure screws a little tiny bit.
So: Don't forget to occasionally check the motor mounts, even when the belts are tight - especially when moving the machine!
