http://imgur.com/wSZYf,ahKNB,Ks5Xr#0
Here is what I have right now, there are three images in this link.
Maybe this video of my Assembly can help you? Theoretically there is every step on it.
Flip the short belt you already have on to the pulley. Then put two more pulleys with two long belts on them on the rod and slide it into the bearing on the other side. Then make sure you get the opposite sides' rod through the belts before you slide it into the bearing cap.
thepandoras 0
http://wiki.ultimaker.com/Ultimaker_3D_models
Or is there a current version of this one?
