Posted · SD card does not "click" in
Hi there,
I am experiencing a hardware related problem with the SD card reader on the Ultimaker 2.
When inserting the SD card in the reader, it does not "click" in. Rather, it pushed slightly back by the small spring. A temporary solution is to tape the card so that the ultimaker is able to read. I am looking for a more permanent solution than this.
You may ask why this happened. The answer is that the printer is used by a bunch of unruly design students who thought it best to forcefully pull the card from the machine.
Any suggestions for a more permanent solution?
