original heat-sensor does not fit in the Ollson Block (UM 2extended)
herman-wouters
Posted (edited) · original heat-sensor does not fit in the Ollson Block (UM 2extended)
I have a "heater error problem" since I installed the Ollson heating block.
I noticed that the sensor could not be fastend any more in the Olsson heating block.
Even if I putsomealu-foliearound the sensor, it will loosen again after a while.
With my Ultimmaker 2 extended igot a spare sensor with cable delivered.
This sensor looks mutch thicker and sticks in the heater the right way.
my question is how to replace the sensor and cable in the machine ????
    Posted · original heat-sensor does not fit in the Ollson Block (UM 2extended)
    Hi @Herman-wouters, if you have found Didier's reply helpful, could you mark it as the best answer? It would help future readers with a similar problem find the best answer the fastest way possible.
    Thank you!
