Nothing happens hitting print
laserwoman
Posted · Nothing happens hitting print
hi guys ... i gotta excavate this old post, because i am having the same issue with Cura 12.12 on windows 7 .... everything worked fine so far (printer head adjusted and running the leveling wizard successfully, gcode created via "prepare print") but then nothing happens after that with "print" button ... is there anything i overlooked?
    same problem with cura 13.03. I've even reinstalled windows, it solved my problem only for one day...
    I had he same of sorts, yesterday I printed the robot, I then changed the Steps per E setting. When I pressed print nothing happened ,the print button stayed highlighted and the printing button was greyed out. Yes I did set the temperature and it was at the set point before I pressed print. I loaded up an older version and it worked fine.
    Paul
        • 24 replies
