The problem of the temperature check up was solved by re conducting the wires in the pcb (I guess). Some were on top of it.I do not know if they caused some kind o interference.
Problem solved by rearranging cables in the PCB, not over it but under and around it.
Cura doesn't work in my Windows 7 32 bit machine. The printing windows with statistics doenst show up.
But it does work in the Mac.
So Now printing!!!
Note the 12.10 release had a bug under windows where the printing window did not show if you did not have a webcam connected. The 12.11 release fixes this.
Daid 301
Is the powerbrick connected and the main power on? (the fan at the bottom should be spinning)
(Note, Cura has become the default software for the Ultimaker, we still need to update some references to RepG on the wiki)
