Printing problem and Stopped Temp Sensor BED
lucdrb
Posted · Printing problem and Stopped Temp Sensor BED
I can't print things greater than 8/10 cm, the piece doesn't stick anymore on the bed and after doing:
tune -> abord,
I got the Stopped Temp Sensor BED message.
I think that that temperature from the bed decrease (can't control it) but for the printer the t° ok on the screen.
Using Ultimaker 2 and cure 15.04.03
Do you have any idea to correct this strange behavior?
Thanks in advance
Luc
    Hi Luc,
    check for any loose wires at the back of the heated bed. Also take off the board cover at the bottom of the printer (it is by two screws only) and inspect the board for any loose or broken connections.
