And does it work when you print from the sd card?
I should normally come on when the nozzle reaches 40°c
Yes, it does work when I print from the SD. That's why I believe it's an Octopi issue...
Problem "solved"!
Actually it disappeared.
After one week I decided to connect the OctoPi to my UM2+ again and now it works!?
I did not change ANYTHING...
IT-god works in mysterious ways...
Well that's strange... but good it works now (i've set your answer as best to resolve the issue)
DidierKlein 730
