UM2+ & Octopi: Rear Fan Issue
zvila
Posted · UM2+ & Octopi: Rear Fan Issue
UM2+ with Octopi: Rear Fan Issue
After just a couple of attempts, I’ve managed to bring my UM2+ to work with OctoPrint on a Raspberry Pi.
Everything works well: file transfer, printing, camera, remote controlling of the process…
However, one thing I can’t bring to function: REAR FAN!
The two fans directed downwards work properly, but the rear fan remains still through the whole printing procedure.
Does anyone have the same issue and – even more importantly – a solution for that?
    And does it work when you print from the sd card?
    I should normally come on when the nozzle reaches 40°c
    Yes, it does work when I print from the SD. That's why I believe it's an Octopi issue...
    Problem "solved"!
    Actually it disappeared.
    After one week I decided to connect the OctoPi to my UM2+ again and now it works!?
    I did not change ANYTHING...
    IT-god works in mysterious ways...
