Oh maybe that was the problem, it wasn't dry yet.
DidierKlein 729
I usually print with glue or some 3dlac spray even with PLA.
With the gluestick the trick is to put some of it roughly and then to take a slightly wet cloth to apply it as good as possible on the whole bed. You don't need to put a lot for it to work!
avogra 68
Don't be so harsh to yourself, I think it makes absolutely sense to use glue with PLA in many cases! At latest when you want to try some other materials, you will be happy to have the experience how to improve the bed adhesion.
You wrote, that the glue was dried by the heated bed? that is exactly what you want, it has to be dry before you start the print.
