Octoprint & pre printing options ?
D4fnk
Posted · Octoprint & pre printing options ?
Hey,
I just started using Octoprint to monitor and control my Ultimaker 2 Extended+ but i have an issue : when i start a printing from Octoprint there is no warmup (either bed or nozzle) and no first layer for the print, it starts the object directly. I switched to RepRap (Marlin/Sprinter) in Cura but it didn't change anything. Also, i have no issue at all when printing from the SD.
I googled it and it seems that there are no way to automatically pre heat the nozzle/bed and extrude some filament (i.e starting the same way as a print from the SD card) and that i have to do it manually for each print, can anyone confirm ?
Or is there a possibility to script it in the Before Print options ?
Thank you
    If you set Cura to RepRap (Marlin/Sprinter) it should generally work. Make sure it uses something like this as the start gcode:
    G21 ;metric values
    G90 ;absolute positioning
    M82 ;set extruder to absolute mode
    M107 ;start with the fan off
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F{travel_speed} ;move the platform down 15mm
    G1 F200 E3 ;extrude 3mm of feed stock
    G92 E0 ;zero the extruded length again
    G1 F{travel_speed}
    M117 Printing... ;Put printing message on LCD screen
    Alternatively you can also add this to the beginning of your .gcode file.
    If you are using Cura 2.1, check your machine's .json file found in "C:\Program Files\Cura 2.1\resources\machines".
    Hope this helps.
