Identify Outer and inner closed loops after the slicing operation
sajis997
Posted (edited) · Identify Outer and inner closed loops after the slicing operation
Hello folks,
I am going through the source of the CuraEngine and I need some help to identify the class members that is responsible for the following operations:
1. After the Slicer we have closed Polygons - which is equivalent to closed loops. Which part of the source code is identifying outer and inner polygons from all those closed polygons.
Thanks
