The preferences file should be saved in in your home directory in .cura (which is a hidden location)
What you could try, is running Cura from a terminal, then you should be able to see an error log.
Strange still no sucsess even after removing pref and re-installing cura.
It really stops slicing after the first object and says "it took xx secondes to export the file." with a progression bar half way there.
How can I run cura in terminal?
This week-end I'm doing a clean system install anyway it might help.
First, start a terminal (you should be able to find it in the finder)
Then, in the black window type:
cd /Applications/Cura/
./Cura/Contents/MacOS/Cura
Thanks for the tip. This is what I get in the terminal once its stops:
Choucroute:Cura lc$ /Applications/Cura/Cura.app/Contents/MacOS/Cura Choucroute:Cura lc$ /Applications/Cura/Cura.app/Contents/Resources/Cura/util/mesh.py:69: RuntimeWarning: invalid value encountered in divide normals[:,0] /= lens/Applications/Cura/Cura.app/Contents/Resources/Cura/util/mesh.py:70: RuntimeWarning: invalid value encountered in divide normals[:,1] /= lens/Applications/Cura/Cura.app/Contents/Resources/Cura/util/mesh.py:71: RuntimeWarning: invalid value encountered in divide normals[:,2] /= lensException in thread Thread-2:Traceback (most recent call last): File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/threading.py", line 552, in __bootstrap_inner File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/threading.py", line 505, in run File "/Applications/Cura/Cura.app/Contents/Resources/Cura/gui/projectPlanner.py", line 978, in OnRun startGCode = profile.getAlterationFileContents('start.gcode') File "/Applications/Cura/Cura.app/Contents/Resources/Cura/util/profile.py", line 534, in getAlterationFileContents return unicode(prefix + re.sub("(.)\{([^\}]*)\}", replaceTagMatch, alterationContents).rstrip() + '\n' + postfix).strip().encode('utf-8') File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/re.py", line 151, in sub File "/Applications/Cura/Cura.app/Contents/Resources/Cura/util/profile.py", line 430, in replaceTagMatch return pre + time.strftime('%d %b %Y')UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 4: ordinal not in range(128)
Looks like a possible problem with language settings. What native language do you have configured in your Mac?
Most likely, removing the "at: {day} {date} {time}" from the start code works around this.
My system language is english, but I use the Swiss-french time and date setting.
On a freshly installed system project-planner works again. If it starts acting strange I'll try removing the gcode you mentioned.
Thanks for the support!
Removing the specified comment in the start.gcode worked for me. I am using French also..
Thanks for the Great Support !
Same here, my brother removed the "at: {day} {date} {time}" on his setup and it works fine again!
Thanks!
Also fixed this for the next release :-) it will no longer stop slicing, and replace none-ascii chars with a question mark (best I can do right now, most of the code is build around ascii strings instead of unicode strings)
lcollomb 0
So I found a quick workaround.
Login as a guest install a fresh copy of cura and sice. This will only work for the first slice and I cannot open the preference panel.
After that I need to delete the guest user and login as a new one in order to slice again… strange.
Maybe it has to do with the preference file? I cannot find where it is saved.
