Posted · Saving custom printer settings as default?
Quick question... Is there a way to keep settings that were adjusted in the advance menu? Example; I changed the material that requires a different setting for the nozzle and heating bed. Going forward - will I have to manually set these EVERY time I print? I looked everywhere to see if I can adjust or make the setting default but can not find anything. Am I missing something?
Thanks,
Brian
