I have found out the problem and it is due to the firmware. Need to get the firmware from source/github/Ultimaker/marlin and modify the define file. Configuration.h has changed as some of the things have been moved to Configuration_adv.h. Make sure the defines like BED_LIMIT_SWITCH is uncommented as well as TEMP_SENSOR_BED set to 1 or 6 depending on thermistor type. Normally 1 is good enough for most 100k thermistor. Use Arduino IDE to compile and upload the firmware to the Ultimaker.
magicxman 0
