Cura 2.1.2 Slicing issue - CuraEngine.exe has stopped working
amagro
Posted · Cura 2.1.2 Slicing issue - CuraEngine.exe has stopped working
I'm having problems during the slicing, a window opens with the indication: "CuraEngine.exe has stopped working".
The model that I was trying to slice is the well know 3DBenchy, I also have this issue with some of my models.
Is there any log file that I can send to you?
Tks
    Posted (edited) · Cura 2.1.2 Slicing issue - CuraEngine.exe has stopped working
    The problem occours with the 3DBenchy but also with others stls.
    Solved in 2.3.0-beta ;)
